FIle Security
FIle Security
Postby misa.djalovic » Wed Dec 20, 2017 9:36 am
I have setup a VPN OnlyOffice Server and now I am implementing OnlyOffice in our web application. But we are thinking about security at the moment. Files our clients store on our server are confidential and on our web app we store them in private area which cannot be publicly accessed. But the config used for the Document Editor instantiation requires a url path to the file.This is where problems occur for us. Is there a way for us to use url in the following format "http/::www.example.com/d/Sn5P-aiZPU4sEKRENDWiySgO_H8HEpS1lOqJMaZakEI,". Can this be done with the use of some plugin?
misa.djalovic
Re: FIle Security
Postby Maxim » Thu Dec 21, 2017 7:49 am
Hello misa.djalovic!
No, i suppose you should create your own request handler. When accessing this handler, you will be given a file and when the JWT is enabled it will provide security
