edit open source onlyoffice
Postby yisusflow » Tue Nov 28, 2017 9:28 pm
I have installed docker in which I have packaged onlyoffice as edit buttons and core functionalities my version is 5.0
yisusflow
Re: edit open source onlyoffice
Postby Maxim » Thu Nov 30, 2017 1:14 pm
Hello yisusflow!
Where is the issue or question?
Postby yisusflow » Thu Nov 30, 2017 9:57 pm
I I need to delete the button to upload files, studying the documentation found that the application is composed of 6 nuclei (server, core, sdkjs, web-apps, dictionaries, sdkjs-plugins) that is more recommensable to enter the container, find and remove that button ? or download the source code make the changes, compile and make it container? Whatever the appropriate solution, I have no idea where that part is located in the code.
Basically I just need to cancel or remove the file upload functionality
yisusflow
Postby Maxim » Mon Dec 04, 2017 7:52 am
Hello yisusflow!
Unfortunately i cannot help you.
Postby yisusflow » Tue Dec 05, 2017 9:45 pm
thanks friend. I managed to access the container in production which was raised with the docker method, now I find the problem that the directory . (DocumentServer/web-apps/apps/api) . no exist. within it is the file that I want to modify ... but becouse ??
yisusflow
