Access to Document Server storage is not secured
Postby konfetov » Thu Oct 26, 2017 3:56 pm
I have found that an access to Document Server to get a document from cache is not secured.
How to reproduce using Confluence Plugin for OnlyOffice Document Server.
1. Edit a document in Confluence with OnlyOffice plugin.
A following url is created to fetch a document from the storage
https://onlyoffice.mydomain.com/cache/f ... output.tmp
2. Then if I type the same URL in another browser / computer I can successfully get the document. So a user which is not logged to Confluence is able to load a document.
Please check if this is an error and why JWT is not used here.
Best regards,
Evgeniy
konfetov
Re: Access to Document Server storage is not secured
Postby Maxim » Mon Oct 30, 2017 11:48 am
Hello konfetov!
Confluence Plugin has not been finalized for now.
