Inactive Users in Edit Mode
Postby webaccounts@kkg.org » Wed Oct 18, 2017 8:47 pm
I have users that will open a document while editing it and then not close the document leaving it open till tomorrow. Is there a timeout or inactivity setting so I can drop them therefor sending the callback to save the edited document back to the original server. Any other suggestions to prevent people from staying in a document forever?
Thanks,
Shawn
webaccounts@kkg.org
Re: Inactive Users in Edit Mode
Postby Maxim » Thu Oct 19, 2017 12:12 pm
Hello Shawn!
We plan to implement force closing sessions but later. There is no timeout of user's inactivity.
Maybe this will help you
Postby webaccounts@kkg.org » Thu Oct 19, 2017 1:15 pm
Is that something that will work with what I need? How do I set that on a timer?
Thanks,
Shawn
webaccounts@kkg.org
Postby Maxim » Thu Oct 26, 2017 1:04 pm
Hello webaccounts@kkg.org!
It's not a timer.
