Permissions doesn't work
Postby bclauss » Mon Sep 25, 2017 9:19 am
Hey everyone,
I'm creating the config object for the js api. In the sharingSettings I added 2 users and one with 'Read Only' access. But when I log in with this user I can still edit the document.
When I change the permissions object, then it works.
So, is the sharingSettings just a way to display the information and not to change the permissions ?
Thanks,
Baptiste C.
bclauss
Re: Permissions doesn't work
Postby Maxim » Mon Sep 25, 2017 11:06 am
Hello bclauss!
Yes. This information is dedicated to show info about file.
Postby bclauss » Mon Sep 25, 2017 11:57 am
Thanks
bclauss
