A PHP script that shows project list and details
Postby spcampbell » Thu Sep 21, 2017 5:06 pm
I put this together to help our team review current projects with most of the key info shown on the screen. Things like documents, comments, tasks, milestones, etc are hyperlinked so you can jump into OnlyOffice from here right to the place you want to see.
https://github.com/spcampbell/OnlyOffice_projectList
It also may help some see how the API works. It's pretty simple once you get the hang of it.
I'll be updating and adding some additional features soon. Always feel free to fork and tweak to fit your use case.
spcampbell
Re: A PHP script that shows project list and details
Postby Maxim » Fri Sep 22, 2017 12:00 pm
Hello spcampbell!
Thank you for sharing with your script!
That's a great idea to review current projects.
