get Xml Custom parts from document
Postby rafik.haceb » Tue Sep 19, 2017 9:27 am
Is it possible to get the xml custom parts from a docx document using the javascript API ? i want to get data stored in a xml custom part to create elements (table, paragraph,...) in the document.
Thanks
rafik.haceb
Re: get Xml Custom parts from document
Postby Maxim » Thu Sep 21, 2017 6:57 am
Hello rafik.haceb!
No
