Open portal in new window after authentication
Postby SandraB » Wed Sep 13, 2017 9:59 am
Is it possible to open the Only Office portal url with the user already logged in after passing the authentication process in another web application? By using the token I suppose. If so, any code example would be highly appreciated.
Thank you very much for your help!
SandraB
Re: Open portal in new window after authentication
Postby Maxim » Fri Sep 15, 2017 12:58 pm
Hello SandraB!
Maybe this is what you need.
