API Requirements
API Requirements
Postby SandraB » Wed Sep 06, 2017 7:24 am
I am new to Only Office and I have some questions that might seem trivial:
Does the API require a certain version of OnlyOffice? Or it works with any version of OnlyOffice?
Does it require some installation? Or is installed by default?
We have a Enterprise Edition Start and somehow I can't make a simple authentication request.
Thank you!
SandraB
Re: API Requirements
Postby Maxim » Wed Sep 06, 2017 1:50 pm
Hello SandraB!
You can use API with any Onlyoffice installation.
Authorization for api
