Problem when doc server and doc storage are in different ip
Postby mahdi » Thu Aug 17, 2017 6:50 am
I installed integrated version of the document server and developed the callback function in a different machine. Now the problem is that while I can access the callback file from the document server but it fails when I want to use it in my simple web page.
When I use a callback function in same machine as document server everything is fine. What could be the reason that it fail in this case.
Sincerely,
Mahdi J.Ansari
mahdi
Re: Problem when doc server and doc storage are in different
Postby Maxim » Thu Aug 17, 2017 11:37 am
Hello mahdi!
I advise you to look at our examples
