Dynamic template creator
Postby debopam » Mon Aug 07, 2017 11:57 am
Is it possible to create standard document templates and replace the placeholders programmatically using the document builder APIs. I found the document builder scripts are very useful, however, it is very time-consuming as well as complex to write the script for a 20 pages legal documents with some graphics. Do you have any service that can automatically parse and convert the document into your document builder scripts? Alo advise if you have any alternative approach.
Thanks, Debopam
debopam
Re: Dynamic template creator
Postby Maxim » Thu Aug 10, 2017 7:08 am
Hello debopam!
Unfortunately there is no such functional.
