Creating "Named Ranges" using docbuilder spreadsheetapi
Postby ethan » Thu Jul 13, 2017 4:30 pm
How is it possible to create "Named Ranges" inside the plugin sdk using docbuilder spreadsheetapi?
ethan
Re: Creating "Named Ranges" using docbuilder spreadsheetapi
Postby Maxim » Fri Jul 14, 2017 8:30 am
Hello ethan!
We are going to add that feature in next releases. But for now there is no way to create "Named Ranges" using docbuilder.
