remove drop-down list of encoding type when uploading .txt
Postby NI3 » Tue Jun 06, 2017 6:39 am
Hi
When we upload a .txt file on OnlyOffice server for editing, it asks for encoding type from drop-down list. I wanted to know is there any way to pass this encoding type in configuration to server so that the user is never asked about this?
NI3
Re: remove drop-down list of encoding type when uploading .t
Postby Maxim » Tue Jun 06, 2017 8:02 am
Hello NI3!
Unfortunately there is no way. The user is supposed to point the editor at what encoding the file should be opened. Is it a problem? What if it needs to open a file in another type of encoding not you used to?
Users browsing this forum: Google [Bot] and 2 guests
