View only mode for pptx
Postby murdolk » Fri Jun 02, 2017 9:17 am
hi everyone.
I'm using Onlyoffice with Owncloud 9.0.8 via integration app. They are running on 2 separate servers.
My question is.
What and where can i change (config files) to enable read only mode (mode: view) for presentations (pptx) and everything else leave as it is (default edit settings for docx and xslx)?
thanks a lot for any help
murdolk
Re: View only mode for pptx
Postby Maxim » Fri Jun 02, 2017 10:56 am
Hello murdolk!
See here
You should disable following values
"edit" => true, "def" => true
Postby murdolk » Fri Jun 02, 2017 12:07 pm
If both of them are disabled then i can not open the pptx in browser in view mode. instead of this browser downloads it every time i'm trying to open it.
Disabling only the first one did the trick :)
"edit" => true, set to "edit" => false,
Now it works so:
i can create and edit docx and xlsx, i can create not editable pptx and i can open it in browser in view mode.
now i need only to remove the option create pptx file from dropdown menu.
thnx a lot Maxim
murdolk
Postby Maxim » Mon Jun 05, 2017 11:08 am
Hello murdolk!
You are always welcome!
