Is there any list of issues where data can be lost?
Postby NI3 » Wed May 31, 2017 4:11 pm
I know some of the scenario where data might be lost for e.g.
1. if a .txt file is uploaded and some chart, table and other objects not supported by .txt are put and then file is converted back to txt file
2. In cell referencing between two different xlsx files etc.
So is there any list of cases where data can be lost that I could refer to so as to take precautions while working with OnlyOffice?
NI3
Re: Is there any list of issues where data can be lost?
Postby Maxim » Thu Jun 01, 2017 7:16 am
Hello NI3!
Unfortunately there is no such list.
