conversion error
conversion error
Postby NI3 » Tue May 23, 2017 5:20 am
I'm using conversion service to convert my document to original format after editing the document. While converting I get an error. OnlyOffice logs shows code :80 as error. Can you help me with this?
NI3
Re: conversion error
Postby Maxim » Tue May 23, 2017 8:51 am
Hello NI3!
This error is common conversion error. Maybe you try to convert smth. that Onlyoffice doesn't support. Please check here.
Postby NI3 » Tue May 23, 2017 10:59 am
Thank you for the help :)
is there any way we can convert new MS Office formats (docx, pptx, xlsx) to old formats(doc, ppt, xls)?
The link you provided doesn't have such combination.
NI3
Postby Maxim » Tue May 23, 2017 11:31 am
Unfortunately there is no way.
Also Onlyoffice doesn't support conversion xlsx to xls , pptx to ppt
