Update field impossible on Windows
Postby nakedfoot » Fri Apr 21, 2017 11:23 am
I've tried OnlyOfficeCommunity on an Ubuntu Server with no problems,
But the Windows version make me crazy.
The install process was quite good,
I've created users normally.
But when i want to update them (change Name or add pics) i only see a pink rectangle in the top right corner with an exclamation mark inside.
What does it mean ?
If anybody had the same issue, and the solution ... ?
Thx.
Slts
nakedfoot
Re: Update field impossible on Windows
Postby Maxim » Fri Apr 21, 2017 11:47 am
Hello nakedfoot!
Check the logs
    C:\Program Files (x86)\Ascensio System SIA\CommunityServer\Logs
    C:\Program Files (x86)\Ascensio System SIA\DocumentServer\Log
    C:\Program Files (x86)\Ascensio System SIA\ControlPanel\Logs
Postby nakedfoot » Fri Apr 21, 2017 6:47 pm
Can't find this directories.
And no revelant file in ONLYOFFICE dir/logs.
(fyi, in installed files in c:/ONLYOFFICE/).
Is there any possibilities with an MySQL issue ?
The ODBC connector installation was a difficult step due to an older version of the driver.
Slts,
nakedfoot
Postby Maxim » Mon Apr 24, 2017 12:27 pm
Hello nakedfoot!
What version of Windows do you use?
Postby nakedfoot » Tue Apr 25, 2017 11:15 am
2012 R2.
slts.
nakedfoot
Postby Maxim » Tue Apr 25, 2017 1:39 pm
We are going to release new version 9.0 (within 3-5 days). Please try to install it.
Postby nakedfoot » Wed Apr 26, 2017 12:18 pm
Nice, ;-)
I'll chk in few days.
Slts
nakedfoot
