Authentication and Security
Postby rev138 » Fri Mar 17, 2017 2:42 am
I recently started testing the Nextcloud app. It works well, but I would appreciate clarification on something:
I am running Document Server via the official docker image, which works without configuration, and the only thing Nextcloud knows about it is the URL. What stops anyone who discovers the url of my Document Server from using it? Is there a way to ensure that only my nextcloud users can access it?
Thanks!
rev138
Re: Authentication and Security
Postby Maxim » Fri Mar 17, 2017 8:01 am
Hello rev138!
ONLYOFFICE Document Server uses tokens generated using the JSON Web Tokens standard.
Postby rev138 » Fri Mar 17, 2017 5:53 pm
What stops anyone else from configuring their nextcloud instance to point to my OO server and use it?
rev138
Postby Maxim » Tue Mar 21, 2017 1:29 pm
JWT - if anyone else do not know your secret key it's not possible to use OO server. All incomming and outcoming requests will be secured by JWT.
Users browsing this forum: Google [Bot] and 2 guests
