Change start page beyond available options
Postby nommaz » Sun Jan 08, 2017 8:20 pm
You can change the start page to My documents on community server. But i would like to instead change it to Common documents. I could probably do it with a url rewrite but would prefer to modify an application config settig or database value instead if available.
Thanks
nommaz
Re: Change start page beyond available options
Postby Maxim » Wed Jan 11, 2017 10:53 am
Hello nommaz!
Unfortunately it's impossible! The OnlyOffice is designed the way that you cannot rewrite url.
