Conversations (XMPP Android) cannot connect to 5222
Postby Schroeffu » Fri Jan 06, 2017 4:04 pm
Hi there,
the very best Android XMPP Client "Conversations" is not able to connect to 5222 XMPP Port. I am running very latest Docker Version.
Conversations does cost a fee @PlayStore, but it can be downloaded4fre at https://f-droid.org/ (Open Source Apps)
Error Message: Incompatible Server
Error Explanation Page: https://github.com/siacs/Conversations# ... ble-server
I get 'Incompatible Server'
As regular user you should be picking a different server. The server you selected is probably insecure and/or very old.
If you are a server administrator you should make sure that your server provides STARTTLS. XMPP over TLS (on a different port) is not sufficient.
On rare occasions this error message might also be caused by a server not providing a login (SASL) mechanism that Conversations is able to handle. Conversations supports SCRAM-SHA1, PLAIN, EXTERNAL (client certs) and DIGEST-MD5.
@onlyoffice developers, can you check that? Is there an old XMPP Version running for OnlyOffice? Or does it not support STARTTLS?
Thanks in advance!
Best Regards
Schroeffu
Re: Conversations (XMPP Android) cannot connect to 5222
Postby Maxim » Tue Jan 10, 2017 11:58 am
Hello Schroeffu!
By default there is unsecured connection is used in OnlyOffice, i suppose this is the reason why you get the error "Incompatible Server".
Postby Schroeffu » Fri Jan 13, 2017 6:34 pm
Hello Maxim,
thanks for your answer. This sounds hard, by default no encryption? Wouldn't you change this to default encrypted?
I would never chat over http without encryption.... never. :-) i guess the most users would like to encrypt their chat too. Couldn't you change this, also that Conversions is working?
Many Regards David
Schroeffu
Postby Maxim » Tue Jan 17, 2017 11:57 am
Hello Schroeffu!
It's hard to say when we eneble encryption but i hope soon.
