Access to portal - IP Security
Postby andresgt2000 » Tue Aug 09, 2016 6:52 pm
Good afternoon
For safety I activate the security option and put ip ranges ip's right to access the portal.
For example I have ranges
LAN - 192.168.0.1-192.168.0.60
Wireless - 192.168.11.1 - 192.168.11-15
VPN - 192.168.70-1 - 192.168.70.30
A level LAN access is allowed but wireless and VPN level, the portal indicates that no access. Although customers if can be registered.
I turn off the ip security and restart the server but still have restricted access from other IP ranges.
How I can do that the portal understand should allow access?
Thank you for your assistance
Note: My installation is made with Docker.
andresgt2000
Re: Access to portal - IP Security
Postby Eugenie » Wed Aug 10, 2016 11:59 am
The issue is detected and fixed and as soon as it is tested, the bug fix will be availabe for download.
At the moment to solve the issue, please do the following:
- activate IP security once again
- delete IP addresses you indicated (in data base)
- clear up lines with IP addresses and deactivate ip security, press save
Eugenie
Postby andresgt2000 » Wed Aug 10, 2016 3:52 pm
Hi Eugine
Is working now.
Thank you very much.
andresgt2000
