Invoice to PDF?
Invoice to PDF?
Postby vvlada » Mon Mar 14, 2016 7:10 pm
Is there an option to save Invoice as PDF to the Documents, for example? How?
Best regards,
Vladimir Vucinic
vvlada
Re: Invoice to PDF?
Postby vvlada » Wed Mar 16, 2016 2:52 pm
Thanks to the Support team, there is an simple answer: install Document Server and you will have Download Option that converts Invoice to PDF (sadly, mine is without logo image and I can not figure out why). Thanks Alex, from OnlyOffice support.
vvlada
Re: Invoice to PDF?
Postby Alex » Wed Mar 16, 2016 3:43 pm
You are welcome )
Alex
