CRM contacts not showing up in search
Postby halbz » Tue Jan 19, 2016 6:43 pm
Not companies but only persons have quit showing up in search results either from the universal search or the filter bar search. I did read on the cloud version forums a similar issue about a year ago but no reply if fixed in cloud version.
http://cloud.onlyoffice.org/viewtopic.php?f=32&t=129
I am currently running Version 8.5.0 on Windows. Is their any fix for this?
halbz
Re: CRM contacts not showing up in search
Postby Dean » Wed Jan 20, 2016 12:49 pm
We had this problem with older version of Sphinx. After we released a 8,6 version it was fixed. Please update and check if the error remains.
Postby halbz » Sun Jan 31, 2016 9:43 pm
Do you know if a Windows server version of 8.6 is planned to be released?
halbz
Postby halbz » Wed Feb 10, 2016 2:02 am
halbz wrote:Do you know if a Windows server version of 8.6 is planned to be released?
we did notice the new 8.7 windows verison but after updating the issue is not fixed
halbz
Postby halbz » Wed Feb 10, 2016 7:31 pm
Nevermind we figured it out, new version works once we setup sphinx correctly.
halbz
