can not generate fonts on windows
Postby hp100277 » Wed Dec 23, 2015 6:38 am
hello! I installed document server 30 on windows 2012 r2,it's fine.
when i add new font refer helpcenter(http://helpcenter.onlyoffice.com/server ... fonts.aspx) ,i need GenerateAllFonts.bat file.
but i can not find this file in tools folder. the folder contains a file:AllFontsGen.exe, i run it and restarted converter service. The fonts is not display.
I really hope for a prompt answer. Thank you.
hp100277
Re: can not generate fonts on windows
Postby Dean » Thu Dec 24, 2015 7:28 am
1. Install the font in the system so it appeared in C:\Windows\Fonts.
2. Run command prompt (as an Administrator)
3. Run:
cd C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE DocumentServer\Tools
4. Run:
AllFontsGen.exe "C:\Windows\Fonts" "C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE DocumentServer\DocService\OfficeWeb\sdk\Common\AllFonts.js" "C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE DocumentServer\DocService\OfficeWeb\sdk\Common\Images" "C:\Program Files (x86)\Ascensio System SIA\ONLYOFFICE DocumentServer\FileConverterService\Bin\font_selection.bin"
5. Restart ONLYOFFICE Converter Service.
6. Clear cache and cookies of the browser.
