OnlyOffice settings not finding up Sphinx.
Re: OnlyOffice settings not finding up Sphinx.
Postby Dean » Tue Feb 09, 2016 8:16 am
Yes, it was. Would you mind checking out the version of ONLYOFFICE installed?
Postby mrman » Wed Feb 10, 2016 5:43 am
This now works on a Standalone version. However, not on docker.
Version 8.7.1 from Docker.
As Sphinx is installed on the host which is running a docker version of onlyoffice (https://github.com/ONLYOFFICE/Docker-CommunityServer), could this be causing the problem?
Can you provide the instructions on how to run Sphinx on a host and connect it to docker? Then I can verify if my setup is correct.
I'm using the current config for docker
sudo docker run -i -t -d -p 443:443 -p 9306:9306 --restart=always -v /opt/onlyoffice/Logs:/var/log/onlyoffice -v /opt/onlyoffice/Data:/var/www/onlyoffice/Data -v /opt/onlyoffice/MySQL:/var/lib/mysql -v /opt/onlyoffice/WebStudio:/var/www/onlyoffice/WebStudio onlyoffice/communityserver
I've tried the logging into Docker instance and running the following commands:
sudo service onlyofficeIndex stop
sudo rm -rf /var/www/onlyoffice/Data/Index/*
mysql -u root -p
use onlyoffice;
truncate table webstudio_index;
exit;
Then I've restarted the host and only 443 is open 9306 remains closed.
mrman
Postby mrman » Tue Feb 16, 2016 2:47 am
Everytime I restart the host I have to clear all the settings in docker... Any ideas why? Then it stops working after 3 minutes.
mrman
Postby mrman » Thu Apr 21, 2016 1:16 am
Is there an update on this, as this key feature of searching is not working we are considering going to Sharepoint...
mrman
Postby mrman » Wed May 04, 2016 3:08 am
Any updates... it's been 3 months....
mrman
Postby Dean » Thu May 05, 2016 12:25 pm
It is working in 8.7. We've checked it. There may be some problems in starting the onlyofficeIndex service but it can be restarted. If it doesn't help, we need logs from the /var/log/onlyoffice/svcIndex.$date.log and /var/log/sphinxsearch.
Postby mrman » Mon Jul 18, 2016 1:27 am
Confirmed working in 8.9
mrman
Postby nommaz » Tue Dec 20, 2016 3:29 pm
Hello new user here!
I couldnt find instructions for sphinx install on standalone.
Yes there is a small bit under troubleshooting but the sphinx.conf resulting with default install surely must be changed to match onlyoffice right?
I saw https://github.com/ONLYOFFICE/Community ... in.conf.in
Tried to replace sphinx.conf with it by supplying database credentials, but had no idea for %LOG_PATH% or other var. Or even if I should be doing this in the first place.
nommaz
Postby 1337hium » Tue Dec 27, 2016 8:29 am
nommaz wrote:Hello new user here!
Same Problem here. Where are the instructions to install/config Sphinx on Ubuntu?
1337hium
Postby Maxim » Wed Dec 28, 2016 12:21 pm
1337hium wrote:Where are the instructions to install/config Sphinx on Ubuntu?
To set up full text search in Community Server under Ubuntu you will need to do the following:
1. Install the latest version of sphinx. Read more details here on how to do that.
2. Stop the sphinxsearch service using the following command:
sudo service sphinxsearch stop
3. Restart the onlyofficeIndex service:
sudo service onlyofficeIndex restart
Automatic installation is not supported for Ubuntu due to the installator security restrictions.
This tutorial is here for Ubuntu and here for Windows.
PreviousNext
