OnlyOffice settings not finding up Sphinx.
Postby mrman » Tue Dec 01, 2015 4:19 am
I've installed and running OnlyOffice Comm on a single host (Not Docker). Sphinx is installed on the host. I get the following error in Sphinx settings when I click test: "Full text service is not running"
I used the following commands to install Sphinx on the host OS Ubuntu 14.04
sudo add-apt-repository ppa:builds/sphinxsearch-rel22
sudo apt-get update
sudo apt-get install sphinxsearch
sphinxsearch version is 2.2.10
I've verified that the port is open on the host from a different host.
In Sphinx settings i tried setting the host as: localhost and IPADDRESS_OF_HOST
mrman
Re: OnlyOffice settings not finding up Sphinx.
Postby Dean » Tue Dec 01, 2015 1:14 pm
It is more correct to use IP-address.
PLease try to restart onlyofficeIndex first.
Postby mrman » Tue Dec 01, 2015 8:36 pm
I've tried setting the host IP and restarted the Index service by running: sudo service onlyofficeIndex restart
However, I'm still getting the message: "Full text service is not running"
mrman
Postby Dean » Wed Dec 02, 2015 11:26 am
1. Are there any data in /var/www/onlyoffice/Data/Index ?
2. What are the access rights to the folder?
Postby mrman » Wed Dec 02, 2015 8:39 pm
There is data in the folder /var/www/onlyoffice/Data/Index which is: binlog.001 binlog.meta community crm files mail projects
Permissions on the folder is: drwxr-xr-x 7 onlyoffice onlyoffice 4096 Dec 2 11:25 Index
I've tried setting the whole folder of /var/www/onlyoffice/Data to 777 recursively through all the subfolder and restart the server. I still have the same issue.
mrman
Postby Dean » Thu Dec 03, 2015 1:17 pm
Please try the following:
Stop sphinxsearch and
echo "Start=No" >> /etc/init.d/sphinxsearch
After that:
1) Stop onlyofficeIndex. Stop processes: searchd, indexer.
2) Clean the folder /var/www/onlyoffice/Data/Index
3) Clear table in the db: webstudio_index
4) Start onlyofficeIndex
In fact, it shall re-launch the Indexation service. Contact us and inform of the results, please.
Postby mrman » Fri Dec 04, 2015 12:29 am
Still didn't work.
I ran the following commands:
sudo service searchd stop
sudo killall -9 searchd
echo "Start=No" | sudo tee -a /etc/init.d/sphinxsearch
sudo rm -rf /var/www/onlyoffice/Data/Index/*
truncate table webstudio_index
I'm still getting the error message: Full text service is not running
mrman
Postby mrman » Tue Dec 08, 2015 7:41 pm
Any ideas, how to fix this?
mrman
Postby Dean » Wed Dec 09, 2015 12:36 pm
Yes, we detected it, our current fixes of the error didn't work according to the Sphinx packages updated, We shall include the fix into the next update.
Postby mrman » Mon Dec 14, 2015 7:33 pm
When is the next update?
mrman
Next
