Slow Community Server (Docker)
Postby mrman » Sun Oct 25, 2015 12:19 pm
Hey All,
I'm having to run the community server in an environment without an internet connection which is causing me some issue with slowness due to the server waiting for a response from various website... which it can as there is no internet connection.
The most obvious hold up with 55ms is:
https://by.uservoice.com/t/94629/x/p/track.js?....
Anyone know where I can comment this out in the codebase to prevent the slow down?
mrman
Re: Slow Community Server (Docker)
Postby AnaMih » Tue Oct 27, 2015 11:42 am
You can make the following:
Open the file /var/www/onlyoffice/WebStudio/web.appsettings.config
Find the lines with the external links in "value". After applying changes restart monoserve.
User avatar
Postby mrman » Fri Oct 30, 2015 12:35 pm
I've removed all external links and the URL is still there...
mrman
Postby AnaMih » Tue Nov 03, 2015 2:01 pm
Delete the url also, please.
User avatar
Postby mrman » Wed Nov 04, 2015 9:50 pm
I have search the file and it doesn't exist anywhere... I assume it's been hardcoded.
mrman
Postby AnaMih » Sat Nov 07, 2015 1:56 pm
Please, make sure that the file "The web.appsettings.config" inside the Docker container has been changed (not the file on your host machine).
You should attach to a docker container and edit the file.
User avatar
Postby mrman » Wed Nov 11, 2015 2:40 am
This is the content of the file:
<?xml version="1.0" encoding="utf-8"?>
<appSettings>
<clear />
<add key="core.base-domain" value="localhost" />
<add key="core.machinekey" value="Vskoproizvolny Salt par Chivreski" />
<add key="core.notify.postman" value="service" />
<add key="core.notify.autoreplyhost" value="localhost" />
<add key="core.payment-region" value="test" />
<add key="core.payment-partners" value="https://partners.teamlab.info/api" />
<add key="web.hide-settings" value="StudioSmsNotificationSettings,VersionSettings,Monitoring,AdministrationPage,WhiteLabel,PublicPortal,MailPrint,Backup,Restore,LdapSettings,LoginHistory,AuditTrail,SingleSignOnSettings" />
<add key="web.cultures" value="en-US,fr-FR,de-DE,es-ES,en-GB,ru-RU,lv-LV,pt-BR,pt-PT,it-IT,tr-TR,el-GR,zh-CN,pl-PL,cs-CZ,uk-UA,vi-VN,fi-FI,az-Latn-AZ,ko-KR,ja-JP,sl-SI" />
<add key="web.display.mobapps.banner" value="files" />
<add key="web.client.bundling" value="true" />
<add key="web.client.store" value="true" />
<add key="web.client.cache.resetkey" value="8.6.0.24" />
<add key="web.transfering.errorstatus-regex" value="/products/files/httphandlers/filehandler\.ashx|/products/files/services/wcfservice/service\.svc" />
<add key="web.portal.test-data" value="false" />
<add key="web.teamlab-site" value="http://www.onlyoffice.com" />
<add key="web.user-forum" value="http://cloud.onlyoffice.org" />
<add key="web.support-feedback" value="http://feedback.onlyoffice.com" />
<add key="web.chat" value="false" />
<!-- XHR type: flash, noflash (with http proxy) or handler (with http-poll handler) -->
<add key="RequestTransportType" value="handler" />
<!-- file uploader type: flash or noflash -->
<add key="FileTransportType" value="noflash" />
<add key="BoshPath" value="http://localhost:5280/http-poll/" />
<add key="web.uservoice" value="" />
<!--IE <= 6, FF<= 3, Safary <=4, Chrome <= 9, Opera <=10 -->
<add key="web.browser-not-supported" value=".*((MSIE\s+(?!(7|8|9|10|11|12|13|14|15)))|(Firefox/(1|2|3)\.)|(AppleWebKit.*?Version[/ ](1|2|3|4)\.)|(AppleWebKit.*?Chrome[/ ](1|2|3|4|5|6|7|8|9)\.)|(Opera.*Version[/ ](?!(10|11|12|13)))).*|^(?!.*MSIE)(?!.*Firefox)(?!.*Safari)(?!.*Opera)(?!.*Trident.*rv:11.0)(?!.*facebookexternalhit).+" />
<add key="api.url" value="~/api/2.0/" />
<add key="web.notenant-url" value="http://www.onlyoffice.com/wrongportalname.aspx" />
<add key="web.import-contacts-url" value="https://service.teamlab.com/import7/import-contacts/importframe.aspx" />
<add key="mobile.urlregex" value="^((?!((/skins/)|(/login\.ashx)|(/wizard\.aspx)|(/confirm\.aspx)|(/api/)|(\.js$)|(/mobile/)|(/products/files/doceditor\.aspx)|(.*/clientscript/.*)|(.*/bundle/.*)|(/products/files/httphandlers/filehandler\.ashx)|(/products/files/services/wcfservice/service\.svc/))).)*$" />
<add key="mobile.regex" value="android|avantgo|playbook|blackberry|blazer|compal|elaine|fennec|hiptop|iemobile|ip(hone|od|ad)|iris|kindle|lge |maemo|midp|mmp|opera m(ob|in)i|palm( os)?|phone|p(ixi|re)\\/|plucker|pocket|psp|symbian|treo|up\\.(browser|link)|vodafone|wap|windows (ce|phone)|xda|xiino" />
<add key="files.thirdparty.enable" value="boxnet,dropbox,google,skydrive,webdav,yandex" />
<add key="files.viewed-images" value=".bmp|.gif|.jpeg|.jpg|.png|.ico" />
<add key="files.uploader.url" value="products/files/" />
<add key="files.uploader.chunk-size" value="5242880" />
<add key="files.docservice.viewed-docs" value=".pptx|.ppsx|.pptt|.ppt|.pps|.odp|.gslides|.xlsx|.xlst|.xls|.ods|.gsheet|.csv|.docx|.doct|.doc|.odt|.gdoc|.txt|.rtf|.mht|.html|.htm|.fb2|.epub" />
<add key="files.docservice.edited-docs" value=".pptx|.ppsx|.pptt|.ppt|.pps|.odp|.xlsx|.xlst|.xls|.ods|.csv|.docx|.doct|.doc|.odt|.txt|.rtf|.mht|.html|.htm|.fb2|.epub" />
<add key="files.docservice.convert-docs" value=".ppt|.pps|.odp|.xls|.ods|.doc|.odt|.rtf|.mht|.html|.htm|.fb2" />
<add key="files.docservice.coauthor-docs" value=".pptx|.pptt|.xlsx|.xlst|.docx|.doct" />
<add key="files.docservice.url.converter" value="" />
<add key="files.docservice.url.api" value="" />
<add key="files.docservice.url.storage" value="" />
<add key="files.docservice.url.command" value="" />
<add key="resources.from-db" value="true" />
<add key="mail.googleOAuth" value="false" />
<add key="mail.download-handler-url" value="/addons/mail/httphandlers/download.ashx?attachid={0}" />
<add key="mail.download-all-handler-url" value="/addons/mail/httphandlers/downloadall.ashx?messageid={0}" />
<add key="mail.view-document-handler-url" value="/addons/mail/httphandlers/viewdocument.ashx?attachid={0}" />
<add key="mail.edit-document-handler-url" value="/addons/mail/httphandlers/editdocument.ashx?attachid={0}" />
<add key="mail.attachments-group-operations" value="false" />
<add key="mail.count-get-first-query" value="3000" />
<add key="mail.count-get-query-interval" value="30000" />
<add key="mail.count-get-query-enable-interval" value="false" />
<add key="mail.server.txt-record-name" value="@" />
<add key="mail.server.spf-record-value" value="v=spf1 +mx ~all" />
<add key="mail.server.mx-record-priority" value="0" />
<add key="mail.server-mailbox-limit-per-user" value="2" />
<add key="mail.server-dkim-selector" value="dkim" />
<add key="mail.server-dns-check-prefix" value="onlyoffice-domain" />
<add key="mail.send-tcp-timeout" value="30000" />
<add key="mail.recieve-tcp-timeout" value="30000" />
<add key="mail.certificate-permit" value="false" />
<add key="mail.no-imap-send-sync-servers" value="imap.googlemail.com|imap.gmail.com" />
<add key="messaging.enabled" value="true" />
<add key="messaging.secret-ips" value="" />
<add key="ipsecurity.enabled" value="true" />
<add key="voip.enabled" value="false" />
<add key="monitoring.log-folder" value="..\Logs\,..\Mail\Aggregator\logs\,..\Mail\Watchdog\logs\" />
<add key="monitoring.service-names" value="OnlyOfficeJabber,OnlyOfficeNotify,OnlyOfficeIndex,OnlyOfficeFeed,OnlyOfficeSignalR,OnlyOfficeMail,OnlyOfficeMailWatchdog" />
<add key="aspnet:MaxHttpCollectionKeys" value="5000" />
<add key="version.number" value="8.6.0.24" />
<add key="saml.request.certificate.password" value="password" />
<add key="web.install-url" value="http://service.teamlab.com/install/email.ashx?v=8" />
<add key="web.client.cache" value="true" />
<add key="web.warmup.type" value="basic" />
<add key="resources.cache-timeout" value="0" />
</appSettings>
mrman
Postby AnaMih » Thu Nov 12, 2015 4:21 pm
Please remove the value "https://partners.teamlab.info/api"
in the string <add key="core.payment-partners" value="https://partners.teamlab.info/api" />
and restart service monocerve in Docker container with Community Server.
If it doesn't help please analyze the external connections that cause delays (in browser console for example).
User avatar
