How to setup development environment
Postby samdubey » Fri Sep 04, 2015 6:27 am
Hello Team,
How to setup development environment to compile ONLYOFFICE on Windows machine using Visual Studio 2013
Since there is no solution file it is quite difficult to arrange/add resources
Thanks,
Sam
User avatar
samdubey
Re: How to setup development environment
Postby AnaMih » Fri Sep 04, 2015 11:27 am
There is the build/Build.bat file in the sources to build the build/msbuild/build.proj with the projects building settings. The is no the single sln-file.
Windows development environment:
1) .Net4.5
2) Visual Studio 2012 and later,
3) Mysql Server,
4) IIS
User avatar
Postby samdubey » Sat Sep 05, 2015 6:09 am
Thank you very much for quick reply
I want to know following:
1. Suppose we deploy docker instance on virtual machine running Ubantu
2. We have changes in source code from Windows Machine
3. How do we deploy changes to docker instance to reflect latest updates
Thanks,
Sameer
User avatar
samdubey
Postby AnaMih » Mon Sep 07, 2015 12:23 pm
To deploy changes to docker you should transfer changers manually and rebuild docker.
User avatar
