Build from scratch and packaging recipes
Postby jw5423 » Sun Jul 26, 2015 4:57 pm
Are there any documets available which go through how to build the ONLYOFFICE products from source ? Also, where can I find the packaging recipes (to build .deb and .rpm) ?
jw5423
Re: Build from scratch and packaging recipes
Postby Dean » Tue Jul 28, 2015 5:05 am
There are scripts of compiling ONLYOFFICE package in the catalogue build/install/deb
Postby jw5423 » Thu Jul 30, 2015 1:59 am
Can you please point me to an exact location for these files. Looking in the repos, I can't seem to find build/install/deb
Thanks
jw5423
Postby Dean » Fri Jul 31, 2015 3:18 pm
I'm terribly sorry for this error - Github sources are for the old version. We will add the instructions about compiling the deb.package asap.
