Edit Documents in the same tab
Postby A_Valverde » Thu Jun 11, 2015 7:36 am
Hi!
I want to disable the "new tab event" when you clik on an element to edit.
Any idea?
A_Valverde
Re: Edit Documents in the same tab
Postby AnaMih » Fri Jun 19, 2015 10:34 am
Unfortunately, there is currently no such function in the onlyoffice interface. We'd recommend to vote for that idea on our feedback forum http://feedback.onlyoffice.com/
You also may customize the software using our source code
Please note that onlyoffice is licenced over the GNU AGPL license.
User avatar
