Edit docs stored in Community Server using MS Office
Postby coisox » Wed Oct 10, 2018 6:16 am
Hi, is it possible to edit document already stored in OnlyOffice Community Server using my laptop's MS Words? Could you point the tutorial? I think I'd stumbled on it but now couldn't find anymore.
I found a topic on WebDav but it seems to setup another server and store docs in that server which I don't want
https://helpcenter.onlyoffice.com/de/se ... buntu.aspx
Secondly, can OnlyOffice generate actual file url so that I can href to
ms-word:ofv|u|https://onlyoffice/file/v2/myfile.docx
coisox
Re: Edit docs stored in Community Server using MS Office
Postby Maxim » Fri Oct 19, 2018 6:59 am
Hello coisox!
You need to download the file on your PC to open and edit it using your laptop's MS Words.
