Amazon Drive Backup?
Postby mormegil49 » Wed Sep 05, 2018 4:10 pm
Hi.
Any plans to add Amazon Drive as an integration option for document backup? Or anyone know of a workaround?
Thanks.
mormegil49
Re: Amazon Drive Backup?
Postby Maxim » Thu Sep 06, 2018 1:44 pm
Hello mormegil49!
If you mean that you would like to connect Onlyoffice portal to Amazon Drive like a third-party service than there is no such plans. At this time Onlyoffice Community Server supports WebDAV protocol only.
Postby mormegil49 » Fri Sep 07, 2018 6:51 pm
Correct - the same as how OnlyOffice is integrated with Dropbox and Onedrive.
Any more details you can provide about connecting to Amazon Drive via WebDAV? Is that a known, working solution?
mormegil49
Postby Maxim » Fri Sep 21, 2018 11:44 am
Hello mormegil49!
If it is ordinary WEBDav it should work.
Postby Carl » Fri Sep 21, 2018 11:47 am
Here you can find an instruction on how to connect other services to Documents module via WebDAV protocol (section 'Other account').
