Loss of comments in .rtf files
Postby NI3 » Tue May 22, 2018 7:44 am
I open a .rtf file in OnlyOffice application and edit the file, put some comments in the document. When downloading the .rtf in .rtf extension, the comments are lost.
NI3
Re: Loss of comments in .rtf files
Postby Maxim » Tue May 22, 2018 8:24 am
Hello NI3!
If you open *.rtf file with Desktop Editor the all changes you have made will be saved in this *.rtf file.
But if you open *.rtf file using Document Server this file will be converted to *docx file. Onlyoffice Document Server doesn't work directly with RTF format. It works with Office Open XML formats: .docx, .xlsx, .pptx.
Where did you edit your *.rtf file? In Desktop or Server Onlyoffice Editor?
Postby NI3 » Tue May 22, 2018 8:28 am
Hi Maxim,
I opened and edited the file in Document Server. And then downloaded it in the same .rtf format and the comment was lost.
NI3
Postby Maxim » Wed May 23, 2018 8:10 am
Hello NI3!
It means that it should be converted at first.
Do you use Document Server only? If it is so you should convert files
Postby NI3 » Wed May 23, 2018 11:54 am
Converted the document back to *.rtf extension. The comment was lost.
NI3
Postby Maxim » Thu May 24, 2018 9:39 am
Hello NI3!
We have detected the bug in displaying comments in RTF format.
Thank you for your information.
