Convert .docx to .docbuilder script
Postby mmeyer » Mon Feb 26, 2018 5:36 am
The "Document Builder" can open an existing .docx file.
Is is possible to save the result als .docbuilder script?
Or are there other possibilities to convert a .docx file to a .docbuilder script?
Regards,
Michael
mmeyer
Re: Convert .docx to .docbuilder script
Postby Maxim » Mon Feb 26, 2018 12:56 pm
Hello mmeyer!
Why do you need this "to save the result als .docbuilder script"? What for?
Postby mmeyer » Mon Feb 26, 2018 2:15 pm
Hello Maxim
Our client wants to allow administrators to create letter templates using word (docx).
These templates will contain placeholders (e.g. ${recipientAddress})
When a normal user opens such a letter template in OnlyOffice the placeholders should be replaced automatically. Instead of ${recipientAddress} the user sees an actual address.
Since find/replace is not supported by Document Builder, I thought this might be a possible workaround:
- Convert the docx template to a docbuilder script
- Use java to replace the placeholders with a script snipped for the actual address
- Use Document Builder to convert the script to a new word document
- Open the new word document in OnlyOffice and allow the user to perform additional edit operations
mmeyer
Postby Maxim » Mon Feb 26, 2018 3:48 pm
Hello mmeyer!
I understand that it will be very helpful to create docs (templates) very fast, but Document Server cannot convert .docx to .docbuilder script
