Mexican Locale
Mexican Locale
Postby apalacios » Tue Jan 09, 2018 11:36 pm
Hi! first of all I thank you for this excellent software!
I'm testing the community version in Spanish. Although the translation is for Spain, it is also appropriate for Mexico. The only drawback is that it uses the European location!
For example, for the location in Mexico the "Peso" is used instead of the "Euro", the "." is used as a separator of decimals and the "," is used as a separator of thousands.
Is there any configuration or file that can be modified to obtain this location while maintaining the Spanish language?
I'm using Community Server 9.5.21 and Document Server 5.0.6, both on CentOS 7 Linux.
Regards and thanks in advance!
apalacios
Re: Mexican Locale
Postby Maxim » Wed Jan 10, 2018 7:19 am
Hello apalacios!
Unfortunately there is no such file.
Re: Mexican Locale
Postby apalacios » Wed Jan 10, 2018 5:59 pm
Hi Maxim, thanks for your reply!
I hope that soon you can expand the list of languages/countries or maybe I can contribute with the translation and localization for Spanish of Mexico.
Best regards!
apalacios
Re: Mexican Locale
Postby Maxim » Thu Jan 11, 2018 8:05 am
Hello apalacios!
It would be great if you take a part in translation process!
Please contact documentation@onlyoffice.com
Re: Mexican Locale
Postby apalacios » Thu Jan 11, 2018 5:40 pm
It will be a pleasure to participate.
Thanks again!
apalacios
Users browsing this forum: Baidu [Spider] and 2 guests
