Create a webapp with Community Edition?
Postby Finn » Fri Sep 01, 2017 1:50 pm
Hi everybody!
If I wanna create a webapp, can I use the API with the Community Edition / Enterprise Edition or is this only possible with the Integration Edition?
Finn
Re: Create a webapp with Community Edition?
Postby Maxim » Mon Sep 04, 2017 10:36 am
Hello Finn!
Yes, you can.
