online help files - documents appear blank
Postby mus » Thu Aug 17, 2017 1:17 pm
Maybe somethings broken in your CMS:
- when i search for documentation on the function "sum" in the help center:
http://helpcenter.onlyoffice.com/search.aspx?text=sum
I get plenty of results in all languages, with a short excerpt. but when i then go to the first search result:
http://helpcenter.onlyoffice.com/onlyof ... s/sum.aspx
Then i only receive an empty page with only the web page template stuff in place.
This happens in all languages an in both the latest chrome and safari on my mac.
Screen Shot 2017-08-17 at 15.16.46.png (163.99 KiB) Viewed 969 times
mus
Re: online help files - documents appear blank
Postby Alexander_mb » Mon Aug 21, 2017 10:47 am
Hello mus,
Thank you for the provided information. We are working on the solution of the problem.
Alexander_mb
Postby Alexander_mb » Mon Aug 21, 2017 12:31 pm
Hello mus,
The problem is fixed, the articles in our Help Center are accessible now.
Alexander_mb
SOLVED online help files - documents appear blank
Postby mus » Fri Aug 25, 2017 9:04 am
Beautiful. Thanks!
mus
