Configuration file in Document server
Postby NI3 » Thu Aug 17, 2017 5:01 am
I have installed open-source binary of document server from the url : http://helpcenter.onlyoffice.com/server ... -apps.aspx on windows 8. I wanted to know the path of configuration file where I can configure jwt inbound and outbound secret key.
NI3
Re: Configuration file in Document server
Postby Maxim » Thu Aug 17, 2017 6:23 am
Hello NI3!
I suppose you need to see here.
Postby NI3 » Thu Aug 17, 2017 10:30 am
Not able to find default.json in Document server distribution for configuring JWT. I referred to the link provided earlier. PFA screenshot for more info.
default json error.JPG (94.28 KiB) Viewed 694 times
NI3
Postby Maxim » Thu Aug 17, 2017 11:56 am
Hello NI3!
Thank you for your notification! Instruction's path is correct too for Document Server!
For Integration version path is %ProgramFiles%\ONLYOFFICE\DocumentServer\example\config\default.json.
