eDirectory LDAP
eDirectory LDAP
Postby leosolo » Thu Aug 03, 2017 11:01 am
Thank you for your wonderful software.
i tried the community version so far and am delighted. but i want to try the ldap connectivity to our edirectory too. i it possible to get an test activation code for the enterprise edition installed an premise here in our company. couldn`t find ldap on the webdemo.
regards
franz
leosolo
Re: eDirectory LDAP
Postby Maxim » Fri Aug 04, 2017 6:53 am
Hello leosolo!
You should install Onlyoffice Enterprise Edition then fill in the form to receive a test 30-day licence key for ONLYOFFICE Enterprise Edition and use it. If you do not have time to test in 30 days you should repeat procedure to get new licence key and continue test period. You can use the same email address again and again.
