Data loss in xlsx file
Postby NI3 » Wed Jul 12, 2017 9:08 am
We have an Excel file (.xlsx) with 3 sheets. When the file is opened in OnlyOffice server, 1st sheet is not displayed and the browser gets stuck when trying to open the 3rd sheet.
Is there anything wrong with the file?
The file is given inside the attached zip for analysis.
(62.32 KiB) Downloaded 28 times
Re: Data loss in xlsx file
Postby Merc » Wed Jul 12, 2017 9:00 pm
When I try to open your document in OnlyOffice or desktop Excel (Mac/2011) I see only two (2) sheets, 1. Vendor Information; 2) security Questions. There is no third sheet.
In OnlyOffice the document uploads and converts as expected. I can open and edit the first sheet fine but when I attempt to open the second sheet Firefox reports and Unresponsive Script Warning and it only opened after I hit the Continue button twice. After that Firefox was pretty unresponsive. I did not receive a warning in desktop Excel.
I am running the current release of OnlyOffice CE for Docker on Ubuntu 16.04.2 LTS.
Postby Maxim » Thu Jul 13, 2017 9:41 am
Hello NI3!
We have detected the problem connected with your test file and will fix it in 4.4.5 version.
Thank you for your information!
Users browsing this forum: Majestic-12 [Bot] and 3 guests
