discussions in Projetx Module & Forum in community module
Postby netchaiev » Tue Jul 04, 2017 2:09 pm
I want to upload an document (PDFfor exemple) in my project and open a discuss to propose a survey but :
-> discussion in module projects :
OK : Good rights for the users,
BAD : Can't upload and link an document on my project folders
BAD : Can't propose a survey
-> Forum in community module :
BAD : Open for every users (can't give detail access for forum [For example: one forum by project]
GOOD : Can upload and link an document on my project folders
GOOD : Can propose a survey
Solution :
Just put the same options for discussion in project that forum in community
Or
Just give user detail access for forum in community module
What is possible to resolv my case ?
netchaiev
Re: discussions in Projetx Module & Forum in community modul
Postby Maxim » Wed Jul 05, 2017 6:34 am
Hello netchaiev!
You can or i didn't understand you correctly
Upload in discussion.png (26.97 KiB) Viewed 775 times
We will think about it. Thank you for your suggestion!
There is no forum
