Uploading and converting .doc and .xls
Postby yanuk » Wed Jun 14, 2017 10:33 am
I am running onlyoffice on Ubuntu with onlyoffice CS and DS in docker.
I am connected to the server via https
When I upload a .doc or .xls file, onlyoffice tries to convert the file but I get this error.
Error occurred in the Documents Service (Error: ConnectFailure (Connection refused))
The file is uploaded properly and the other functions seem to operate well. Editing XLSX and DOCX files work well.
yanuk
Re: Uploading and converting .doc and .xls
Postby Maxim » Wed Jun 14, 2017 1:14 pm
Hello yanuk!
Community Server cannot connect to the Document Conversion Service Address for some reason. Try next
1 Reboot containers
2 In Settings -> Document Service -> Document Conversion Service Address you'll find
http://onlyoffice-document-server/ConvertService.ashx
Put IP address of document serves' container instaed of onlyoffice-document-server, smth. like
http://10.0.7.2/ConvertService.ashx
You will point Community Server how to connect to the Document Server.
3 Reinstall containers.
Postby yanuk » Wed Jun 14, 2017 1:41 pm
coo! #2 did it for me.
I was determined to have a more elegant solution in case the container IPs change in future; I stopped the containers, deleted the bridging network, recreated the network, started the containers again and it stopped working again.
I realised that the settings defaulted to HTTPS
I changed HTTPS to HTTP and it's all good now permanently!
Great stuff!
yanuk
Postby Maxim » Thu Jun 15, 2017 6:08 am
Hello yanuk!
I hope you enjoy Onlyoffice ;)
