Issue with white labeling in mobile devices
Postby NI3 » Sat Jun 10, 2017 1:11 pm
We have Integration edition of OnlyOffice server with white labeling enabled. The server is deployed on Windows machine. In config.json we put our customization tag according to https://api.onlyoffice.com/editors/config/editor/customization.
So the issue is that customized parameters are properly displayed in about section in desktop devices but in mobile devices, instead of customized parameters OnlyOffice parameters are displayed in about section.
Why is this happening even when white labeling is enabled?
NI3
Re: Issue with white labeling in mobile devices
Postby NI3 » Tue Jun 13, 2017 4:52 am
Can someone please look into the issue?
NI3
Postby Maxim » Tue Jun 13, 2017 6:37 am
Hello NI3!
Please attach screenshot with the issue or maybe you can share a link to see what exactly displays improperlyif it's possible
Postby NI3 » Tue Jun 13, 2017 7:45 am
Thank you for taking up this issue :D .
Please find attached the zip file. The zip file contains two jpg files, one for mobile view and another for desktop view of about section.
Looking forward to your reply.
Thank you.
WhiteLabelingIssue.zip
(83.51 KiB) Downloaded 37 times
NI3
Postby Maxim » Tue Jun 13, 2017 11:23 am
Hello NI3!
Thank you for the information! We have found a bug! We will fix it next relese!
Postby NI3 » Tue Jun 13, 2017 11:46 am
Thank you.
NI3
Postby Maxim » Wed Jun 14, 2017 8:10 am
You are always welcome!
