DocumentServer isnt saving
Re: DocumentServer isnt saving
Postby Maxim » Thu Jun 01, 2017 7:12 am
Hello progressguide!
Do you use self-assigned certs? There is a problem to run HTTPS using self-assigned certs and PHP.
Postby Taste » Thu Jun 22, 2017 11:13 am
I have the same problem. Errors in NC:
file_get_contents(https://XXX:8888/cache/files/1750214981 ... utput.docx): failed to open stream: operation failed at /var/www/xxx/web/apps/onlyoffice/controller/callbackcontroller.php#376 2017-06-22T13:11:21+0200
Error PHP file_get_contents(): Failed to enable crypto at /var/www/xxx/web/apps/onlyoffice/controller/callbackcontroller.php#376 2017-06-22T13:11:21+0200
Error PHP file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed at /var/www/xxx/web/apps/onlyoffice/controller/callbackcontroller.php#376
any news to that?
Solved by this Thread: https://github.com/ONLYOFFICE/Docker-Do ... /issues/54
Taste
Previous
