Possible to integrate Personal Use server with NextCloud?
Postby jackalope » Sun Oct 14, 2018 10:50 pm
I have a personal nextcloud server. I can connect to it in my personal use OnlyOffice using WebDav. But I'd also like to have it more fullyintegrated into my NextCloud app. To do that, the app integration needs to know the document server address:
Is it possible for me to do that with my Personal Use OnlyOffice implementation on the only office website?
jackalope
Re: Possible to integrate Personal Use server with NextCloud
Postby Carl » Mon Oct 15, 2018 9:58 am
This is not possible. You have to use your own Document Server to be able to connect it to Nextcloud. Instructions can be found here.
Postby jackalope » Mon Oct 15, 2018 7:54 pm
Thanks for the info!
jackalope
Postby Carl » Thu Oct 18, 2018 9:13 am
Let us know if you have any other questions.
