Integration issue
Integration issue
Postby VG.ethica » Thu Sep 20, 2018 9:48 am
I have Nextcloud and OnlyOffice Document Server installed on the same server (OnlyOffice Document Server on a docker, internal docker port 443 and external 4443) with the same Certificate.
I can access them both from public network (Nextcloud: https://cloud.XXX.it/nextcloud - OnlyOffice Document Server: https://cloud.XXX.it:4443) and intranet (Nextcloud: https://192.168.XXX.YYY/nextcloud - OnlyOffice Document Server: https://192.168.XXX.YYY:4443).
I tried to configure the integration between Nextcloud and OnlyOffice Document Server with the following parameters:
Document Editing Service address: https://cloud.XXX.it:4443
Document Editing Service address for internal requests from the server: https://192.168.XXX.YYY:4443
But I have always the error Error when trying to connect (Bad Request or timeout error).
Please... help me!!!!!!!!!!!!!!!!!! :cry: :cry: :cry:
VG.ethica
Re: Integration issue
Postby Carl » Fri Sep 21, 2018 11:30 am
Please clear the fields of "advanced server settings" and close them. Try to leave only Document Editing Service address filled (https://cloud.XXX.it:4443) and check if the settings can be saved.
