"New file" creation disappearance
Postby batches » Tue Jul 17, 2018 9:12 pm
Hi eveybody!
Could you assist me with the following issue?
Some time after installation new file types disappear from "New file" and context menus.
We tried full reinstall about 5 times already. Sometimes it disappears after 1 hour, sometimes after several days.
We still can open documents by direct link, for example: .../index.php/apps/onlyoffice/305#
It opens corresponding onlyoffice app.
We use Docker installation with this composer script:
https://github.com/ONLYOFFICE/docker-onlyoffice-owncloud
Nextcloud 12.0.9
Onlyoffice 5.1.4.22
running on nextcloud server:
curl http://onlyoffice-document-server
response:
<title>302 Found</title>
302 Found
nginx
running on office server:
wget http://nginx-server/
response:
--2018-07-15 14:41:58-- http://nginx-server/
Resolving nginx-server (nginx-server)... 172.18.0.2
Connecting to nginx-server (nginx-server)|172.18.0.2|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://nginx-server/index.php/login [following]
--2018-07-15 14:41:58-- http://nginx-server/index.php/login
Reusing existing connection to nginx-server:80.
HTTP request sent, awaiting response... 200 OK
Length: 7047 (6.9K) [text/html]
And when I click "save" in settings, I get the following error:
batches
Re: "New file" creation disappearance
Postby Maxim » Fri Aug 10, 2018 9:03 am
Hello batches!
Maybe this will help you.
