OnlyOffice SaaS with Owncloud
Postby Beryllium » Fri Jul 13, 2018 12:07 pm
Is it possible to integrate the SaaS version of OnlyOffice with an Owncloud installation? If so where can the address for the document server be found?
Beryllium
Re: OnlyOffice SaaS with Owncloud
Postby Maxim » Mon Jul 16, 2018 7:13 am
You can connect Owncloud to SaaS via WebDAV protocol
