password protected documents
Postby jsfrerot » Thu Jun 14, 2018 5:43 pm
I read here that password protected files should be fully supported now (without removing password protection): viewtopic.php?f=3&t=9301
However I am running the latest document server docker image with the onlyoffice nextcloud plugin version 1.3.0, and when importing a password protected docx files, the first time I open it, it asks me for the password, but when saving there is no password anymore.
Is this something to be addressed in the nextcloud/owncloud plugin or is it still an issue with the document server ?
This feature is really important for me.
Thank you.
jsfrerot
Re: password protected documents
Postby Carl » Fri Jun 15, 2018 7:11 am
This is not an issue of Nextcloud plugin, it is the way the document server operates: currently it cannot save passwords of the documents, only read them. Unfortunately, we have no exact date of when this feature is going to be implemented. We regret the inconvenience.
