Onlyoffice Docker + Nextcloud with certs from internal CA
Postby supersonicwaffle » Tue Apr 17, 2018 5:57 am
Hey,
I hope someone can help me out with this.
I'm running https://github.com/nextcloud/vm and everything was working well until I wanted to move things over to certificates issued by my self signed internal CA.
Both the Nextcloud VM and the docker container trust the CA and doing a wget https://office.xxx.com/web-apps/api/documents/api.js works without a hiccup.
Apparently though getting NodeJS to trust these certificates is a major PITA, currently I get these error messages in /var/log/onlyoffice/documentserver/converter/out.log
nodeJS - error downloadFile:url=https://cloud.xxx.com/apps/onlyoffice/download?doc=K01zS29TVUhhejYzYnoySktSVXhBUzAvN01TUkdTUmpBY0kyT044U2wrWT0/eyJmaWxlSWQiOjQ1MiwidXNlcklkIjoibmNhZG1pbiIsInRva2VuIjpudWxsLCJhY3Rpb24iOiJkb3dubG9hZCJ9;attempt=3;code:UNABLE_TO_VERIFY_LEAF_SIGNATURE;connect:undefined;(id=452_1517341481)
Error: unable to verify the first certificate
I have tried running the docker container with "-e NODE_TLS_REJECT_UNAUTHORIZED=0" for testing purposes to no avail.
Is there anything else I can do?
Cheers
supersonicwaffle
Re: Onlyoffice Docker + Nextcloud with certs from internal C
Postby Maxim » Thu Apr 19, 2018 11:22 am
Please specify what version of the Document Server you have installed.
Postby supersonicwaffle » Thu Apr 19, 2018 4:48 pm
Thanks Maxim.
Pardon my ignorance but could you please tell me of a good way to show the document server version?
Cheers
supersonicwaffle
Postby Maxim » Thu Apr 26, 2018 1:06 pm
docker ps
